It is currently Tue Nov 24, 2026 2:21 pm
 Post subject: carburetor question?
PostPosted: Fri Oct 01, 2010 7:39 pm
i was wondering if it's a good idea to put a 2.3l- 2bbl carb. off of a 70's vega or pinto or something like that and hook it up to my stock 225? i heard i will improve on mileage and performance? any help is greatly appreciated![/b]
PostPosted: Sat Oct 02, 2010 1:51 pm
Skeptical Department:
I don’t understand how a carburetor from a smaller (2.3 L) engine can both improve mileage & performance on a 60 % larger 3.7 L slant. Maybe an improvement in mileage can be gained by being under carbureted, but a performance increase?
Would this be a progressive two barrel by any chance? What is the cfm rating of that carburetor?
PostPosted: Sat Oct 02, 2010 3:52 pm
Somebody correct me if I am wrong,
The carb you are talking about is a holley version of a Weber 32 36 that is a staged two barrel. The mileage increase is a result of a smaller primary jet which is used during cruise and, the performance increase is a result of a larger secondary jet along with a much larger airflow used during acceleration.
Hope this helps
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Oct 02, 2010 4:23 pm
carlherrnstein:
Hope this helps
Not yet.
What is the flow capabilities of this carburetor?
I have driven from new Pinto, & Ford Ranger 2.3 L powered conveyances’ equipped with progressive carburetors, as well as my 2.6 L LeBaron, all three of which stink for economy & power.
PostPosted: Tue Oct 05, 2010 1:30 pm
From what I have been able to find just from a quick search on google, a holley 5200/ webber 32/36 can be set up for a cfm rating from 180 cfm to 350 depending on the air horns are installed.
85 d-100 HEI 2BBl
06 Toyota Corrola
Users browsing this forum: Amazon [Bot] and 3 guests
