It is currently Fri Oct 23, 2026 11:02 pm
PostPosted: Mon Sep 23, 2002 2:35 pm
Is there a 4 barrel intake manifold that will bolt to the factory exhaust manifold using the center stud.
My AC bracket anchors to this stud.
In the future I would like to use the front casting for a Dutra setup.
I am just planning the next stages for my buildup.
Any advice would be appreciated.
Killin5@yahoo.com
PostPosted: Tue Sep 24, 2002 5:35 am
: Is there a 4 barrel intake manifold that will
: bolt to the factory exhaust manifold using
: the center stud.
: My AC bracket anchors to this stud.
: In the future I would like to use the front
: casting for a Dutra setup.
: I am just planning the next stages for my
: buildup.
: Any advice would be appreciated.
The Offy 4bbl intake will bolt to a stock ex man, BUT the stud ends up almost underneath the carb.
You may not be able to bolt the AC bracket there, but I'm sure it can be moved somewhere else - maybe one of the engine lifting holes on the top of the head??
PostPosted: Tue Sep 24, 2002 11:51 am
: The Offy 4bbl intake will bolt to a stock ex
: man, BUT the stud ends up almost underneath
: the carb.
: You may not be able to bolt the AC bracket
: there, but I'm sure it can be moved
: somewhere else - maybe one of the engine
: lifting holes on the top of the head??
: Lou
Thanks, that is what I needed to know. I was thinking about moving the bracket over there.
John
Killin5@yahoo.com
PostPosted: Thu Nov 07, 2002 10:23 am
: the carb.
This is true, I just ground down that bolt a little bit. I have the Offy intake with a Dutra manifold on the front, and a mod. factory manifold on the rear. :twisted:
'78 Volare 225
'67 Charger 318
PostPosted: Fri Nov 08, 2002 7:09 am
I was able to put a clifford intake on with the factory exhaust. I had to plate off the heat riser on the exhaust with a chunk of 3/16" steel plate and a normal heat riser gasket. The intake needed to have some material removed from the bottom side. It is cast with enough material on the bottom that would probably allow one to machine it to accept the exhaust in a normal way. I didn't care about that, so I cut that boss off and capped off the heat riser and it worked great.
Side note. Those bottom triangle washers near the center of the head are real hard to get on. I tack welded a small piece of wire to the washer so I could dangle it in from above and hold it in place while I fead the nut in from underneath. After it's all assembled, I just folded the wire back down out of sight.
matt-
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 9 guests
