carburetor question?
https://slantsix.org/forum/viewtopic.php?t=42120
Author:  lucille1964 [ Fri Oct 01, 2010 7:39 pm ]
Post subject:  carburetor question?
i was wondering if it's a good idea to put a 2.3l- 2bbl carb. off of a 70's vega or pinto or something like that and hook it up to my stock 225? i heard i will improve on mileage and performance? any help is greatly appreciated![/b]
Author:  wjajr [ Sat Oct 02, 2010 1:51 pm ]
Skeptical Department:
I don’t understand how a carburetor from a smaller (2.3 L) engine can both improve mileage & performance on a 60 % larger 3.7 L slant. Maybe an improvement in mileage can be gained by being under carbureted, but a performance increase?
Would this be a progressive two barrel by any chance? What is the cfm rating of that carburetor?
Author:  carlherrnstein [ Sat Oct 02, 2010 3:52 pm ]
Somebody correct me if I am wrong,
The carb you are talking about is a holley version of a Weber 32 36 that is a staged two barrel. The mileage increase is a result of a smaller primary jet which is used during cruise and, the performance increase is a result of a larger secondary jet along with a much larger airflow used during acceleration.
Hope this helps
Author:  wjajr [ Sat Oct 02, 2010 4:23 pm ]
carlherrnstein:
Hope this helps
Not yet.
What is the flow capabilities of this carburetor?
I have driven from new Pinto, & Ford Ranger 2.3 L powered conveyances’ equipped with progressive carburetors, as well as my 2.6 L LeBaron, all three of which stink for economy & power.
Author:  carlherrnstein [ Tue Oct 05, 2010 1:30 pm ]
From what I have been able to find just from a quick search on google, a holley 5200/ webber 32/36 can be set up for a cfm rating from 180 cfm to 350 depending on the air horns are installed.
