| Testinga electronic control module https://slantsix.org/forum/viewtopic.php?t=42147 |
| Author: | flipfloppop [ Mon Oct 04, 2010 5:40 pm ] |
| Post subject: | Testinga electronic control module |
I have look and look but can't find. How do I check a electronic control module to see if it is good or not? Thanks for any help you have. |
| Author: | DusterIdiot [ Mon Oct 04, 2010 8:36 pm ] |
| Post subject: | Need a special tool... |
There used to be an old Mopar EI checking tool (basically plug it in and see if the lights light up for a good EI). Not sure if anybody ever ended up with one of those boxes...it's kind of a limited use item to have around the garage. -D.Idiot |
| Author: | wjajr [ Tue Oct 05, 2010 4:28 am ] |
I just toss it into a bucket of water. If it sinks, I flip a coin, heads install a unit that I know works, tails I install a unit I know works, and than discard the wet one. Just kidding, I don’t really use water… One thing you can check is that the unit has a good ground, necessary for proper operation. The spare unit is your test device… |
| Author: | '68signet [ Tue Oct 05, 2010 4:32 pm ] |
So here is another question on a related subject (if I may but in ). Should I be getting shocked (feeling electrical current) from my ECU when my fingers are touching both the center metal "button like device" and the heat sink? I say no but then again, there are a lot of other people here that are more knowledgeable on this subject than me. |
| Author: | 4speed [ Tue Oct 05, 2010 4:51 pm ] |
Short answer is yes-Just like the one you get across the points and for the same reason (has to do with collapsing magnetic fields/lines of force that make the big spark) |
| Author: | flipfloppop [ Wed Oct 06, 2010 2:01 pm ] |
Thanks for the help. I forgot to put a jumper wire on the ballist resistor . I got it running for now. Thanks, Roger |
