It is currently Mon Nov 23, 2026 9:38 pm
 Post subject: Engine Build
PostPosted: Sun Oct 10, 2010 5:47 pm
I made a comment on this thread: http://www.slantsix.org/forum/viewtopic.php?t=42175 and Rick Covalt said he expects to see my triple Weber set-up in person at next year's Mason Dixon race.
So I guess I need to start a thread on a potential engine build that utilizes my triple Weber set-up as I'm quite the neophyte as far as engine builds are concerned. I have looked at other builds on the engine matrix thread and all sound like good builds. However it appears that most use a single carburetor (1, 2 or 4 barrel) with no multi-carb builds at all. So this is likely new ground to cover.
Other than the triple Weber with a matched set of DCOE40s, oversize S/S valves from engnbldr, and 340 valve springs, I'm open to suggestions. One of the members over at MoparMarket.com (Aussie forum) stated the DCOE40s would be great in a torque motor build-up. Sounds perfect to use in my 65 Dart wagon with a 904 and 8.75 with most likely a 3.23 SG. The wagon will be strictly a cruiser-type car (other than maybe a pass or two at Hagarstown next year).
I have 2 slants that are likely candidates: awhile back I picked up an engine that the PO had built in 1991. It's never fired! PO stated other than the stock rebuild, he had the machine shop add hardened seats and a double roller timing chain and windage tray that he had. So I figure stock camshaft, head uncut, etc. The other engine I have came out of a 66 Barracuda I parted out. IIRC it had 5 freeze plugs, so probably a later engine and it's internal condition is unknown. I realize either engine will need to be upgraded with more compression, better cam, etc.
I'm sure if I posted this over at FABO, I'd get the "forget the slant and swap in a 318/340/360" comments. I'm open to any and all suggestions for an engine build that utilizes my triple Weber set-up. So let's hear your suggestions!
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Oct 10, 2010 5:51 pm
I would certainly deck the block for compression.
......and that means new pushrods.
PostPosted: Sun Oct 10, 2010 7:22 pm
i also have a triple weber manifold and will be following this closly to see how yours ends up. i only have the clifford manifold right now, need to save up and buy carbs.
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
