It is currently Mon Nov 23, 2026 11:46 pm
 Post subject: Aluminum Radiator
PostPosted: Thu Oct 07, 2010 11:01 am
Hi, I was wondering if anyone is using an aluminum radiator with electric fan and is it worth the investment. (Even though I already bought it) I hear getting rid off the stock fan will give the six more horsepower. True or false? Thanks
PostPosted: Thu Oct 07, 2010 1:25 pm
Using an electric fan should free up a few ponies, but I haven't installed one yet. That is a future upgrade that I've been planning.
About the aluminum radiator, I don't know. I do know that a lot of guys are using aluminum rads though.
'78 Volare 225
'67 Charger 318
PostPosted: Thu Oct 07, 2010 2:14 pm
There are too many variables (What kind of engine-driven fan? What kind of electric fan? What RPM? etc.) to put a number what an electric fan will do for you. Properly setup, it will free up some horsepower when it's not running. Here's a CAR CRAFT article on fan losses.
I'd like an aluminum radiator, but I'll wait until I have to replace this one.
I'm more interested in the electric fan and other cooling improvements as I creep toward installing my AC.
PostPosted: Sat Oct 09, 2010 4:37 am
I swapped to an aluminum radiator after the stock radiator gave out. I'm incredibly pleased with the swap, and would make the same choice in a heartbeat.
- Mac
PostPosted: Sat Oct 09, 2010 6:45 am
dont forget to add addative to antifreeze to stop corrision
PostPosted: Sat Oct 09, 2010 9:07 am
Additives are typiclly not needed these days with the use of many aluminum parts thanks to the OEM's. Just make sure the antifreeze says safe for aluminum.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Oct 09, 2010 11:42 am
If you go the electric fan route (a good idea) do not forget to wire up a thermal switch to control it and a manual by-pass switch "just in case". As far as the aluminum radiator it will work as well/better that the factory brass one with one problem-winter salt will corrode it far faster. It will depend on how well the maker anodized it. I know you are in Oceanside Calif "mostly a bar for the Marine base, I know as I lived there for 30 years :)" but If you are in a snowy part of the country it is worth thinking about.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Sat Oct 09, 2010 2:47 pm
You can fix a brass radiator with a small seam leak yourself with a torch and some solder..............................
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
