It is currently Tue Nov 24, 2026 8:27 am
PostPosted: Wed Oct 06, 2010 9:27 am
Car Model: 1964 Dodge Polara 2 Dr HT /6 3spd man
I need what I believe is called a Vacuum Valve. It is the plastic piece, about 3/4" in diameter, that operates the air breather, hot air door.
The part number I have come up with is #4201385, but was told it is no longer available from Chrysler.
Any ideas on where I can get one?
BTW, it's for my 87 B150 225
Thanks in advance
1964 Dodge Polara 2dr HT /6 3spd man.
 Post subject: google says
PostPosted: Wed Oct 06, 2010 10:24 am
Try Rock, don't forget the discount code in the Slanted Network section.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Wed Oct 06, 2010 11:15 am
Thanks.
Question: How do I find the slant six discount and code you were referring to?
PostPosted: Wed Oct 06, 2010 1:17 pm
Scroll down to the bottom of this page. Click where it says "jump to: Select a forum". A drop-down menu should drop down. Click on "Slanted Network", and hit "go", if necessary. Click on the third post down, "Rock Auto discount code." Enter a current code into the "how did you hear about us?" box on the Rock Auto shopping cart, and you're good to go! 8)
PostPosted: Wed Oct 06, 2010 1:49 pm
Got it, thanks for your help.
