| Anyone know the exact size of the bolt... https://slantsix.org/forum/viewtopic.php?t=4217 |
| Author: | Palanth [ Tue Sep 24, 2002 6:06 am ] |
| Post subject: | Anyone know the exact size of the bolt... |
...to fit the end of a 1970 slant six crankshaft? The big one to put in to install the balancer or use to turn the engine. I will need to go get one. Thanks. vze28st5@verizon.net |
| Author: | Craig [ Tue Sep 24, 2002 9:05 am ] |
| Post subject: | Re: Anyone know the exact size of the bolt... |
The thread size is 3/4-16. 3/4" diameter, 16 threads per inch. I don't have a length to tell you but you should be able to figure that out. cfield@ll.net |
| Author: | Palanth [ Tue Sep 24, 2002 9:19 am ] |
: The thread size is 3/4-16. : : 3/4" diameter, 16 threads per inch. I : don't have a length to tell you but you : should be able to figure that out. Many thanks. Never had to get one before and unfortunately I do not own a V-8 Mopar to borrow one from. vze28st5@verizon.net |
| Author: | Palanth [ Tue Sep 24, 2002 11:34 am ] |
: The thread size is 3/4-16. : : 3/4" diameter, 16 threads per inch. I : don't have a length to tell you but you : should be able to figure that out. Hold on...3/4 inch? As in 3/4 inch diameter shaft? That sounds awfully big... vze28st5@verizon.net |
| Author: | Doc. [ Tue Sep 24, 2002 12:40 pm ] |
: The thread size is 3/4-16. : : 3/4" diameter, 16 threads per inch. I : don't have a length to tell you but you : should be able to figure that out. Vibration Dampener Bolt 3/4-16 UNF, 2.3 inches long total.(1.5 Min. thread area) It will also need a big thick washer. DD |
| Author: | Palanth [ Tue Sep 24, 2002 2:08 pm ] |
: Vibration Dampener Bolt 3/4-16 UNF, 2.3 inches : long total.(1.5 Min. thread area) : It will also need a big thick washer. : DD Wow, that is one huge bolt. Thank you for the missing spec. vze28st5@verizon.net |
