Hotchkis VS. other sway bars
https://slantsix.org/forum/viewtopic.php?t=42170
Author:  Old Car Scott [ Wed Oct 06, 2010 11:29 am ]
Post subject:  Hotchkis VS. other sway bars
Have you guys seen the hollow 1 1/2" front sway bar offered by Hotchkis? Largest I've seen so far for a Mopar A body and kind wondering what y'all think of it.
Logic would dictate that it offers a better torsional resistance than a 1 1/8" bar and thus better handling, but the Hotchkis piece is hollow vs. most others being solid so there is that variable element.
I've used the solid Hellwig 1 1/8" front bars on other Mopar A, B, and E bodies I've owned, love the improvement in handling and drivability and was wondering the larger Hotchkis bar would be an improvement even over the Hellwig bar.
The Hotchkis piece carries a hefty price tag, too, but it does include all the hardware, down to the tabs that weld to the control arms. Hellwig had a decent k-frame attachment but the control arm end was sketchy and vice-versa of the Addco front bar.
Wondering if there was a really noticable difference between the two swaybars, and what everyone else thought overall.
Author:  Dart270 [ Wed Oct 06, 2010 1:48 pm ]
I assume you mean this:
http://www.hotchkis.net/6772_dodge_abod ... y_bar.html
Hard to say without knowing the wall thickness. It is probably a bit stiffer than your 1 1/8" bar and about 1/2 the weight, but you should check with them. The only reason to have this is weight savings (7-12 lbs savings is my guess) and possibly better mounts than other brands.
I doubt you would notice an improvement over the Hellwig bar, unless the mounts are more rigid or better geometry on the Hotchkis. I've never used a Hellwig, and have custom fabbed mounts that don't break and are a bit better geometry to mount my Addco bars.
Author:  andyf [ Wed Oct 06, 2010 4:54 pm ]
I'm putting a Hellwig tubular bar on a car right now. It is a very nice piece of hardware and the mounting kit is very heavy duty. We're putting it on for the weight savings. 6 lbs off the nose of the car is really important on this car.
