| Socket for kickdown band adjusment https://slantsix.org/forum/viewtopic.php?t=42182 |
| Author: | Springer [ Thu Oct 07, 2010 10:14 am ] |
| Post subject: | Socket for kickdown band adjusment |
Is there a socket for the TF 904 front band adjustment screw? The screw has a square end and it is quite difficult to adjust the correct torque without a socket which fits in to that screw and torque wrench. Where can you buy it? |
| Author: | makapipi [ Thu Oct 07, 2010 10:52 am ] |
a 8 point 1/4" socket should fit. |
| Author: | slantzilla [ Thu Oct 07, 2010 2:44 pm ] |
Break the locknut loose, screw the band adjuster down a good finger tight, back off 1-1/2 turns, tighten locknut. |
| Author: | bigslant6fan [ Thu Oct 07, 2010 10:27 pm ] |
| Post subject: | - |
8 point 5/16" socket.Most chinese 1,001 piece socket sets have these.Just remember the factory specs of 41 inch LBS then loosen it X amount of turns is for use with the factory adapter tool that alters the torque reading of your torque wrench.Check the 7 digit part # of your trans,then obtain the correct service manual for the model year.Then notice possible torque spec differances between S/6 and V-8 904 transmissions. |
| Author: | Springer [ Fri Oct 08, 2010 3:40 am ] |
Thank you for the answers. We have two canditates, 8 point 1/4" and 8 point 5/16, I will try both and hopefully one of those will do the job. I have the FSM and the correct torque spec. |
| Author: | emsvitil [ Fri Oct 08, 2010 4:34 am ] |
Why wouldn't a 12 point work? |
| Author: | slantzilla [ Fri Oct 08, 2010 2:25 pm ] |
Quote: Why wouldn't a 12 point work?
It will. |
| Author: | 66aCUDA [ Sun Oct 10, 2010 6:22 am ] |
Quote: Break the locknut loose, screw the band adjuster down a good finger tight, back off 1-1/2 turns, tighten locknut.
+1 Listen to Dennis He has done more than one. and this is EASY!!! Frank |
| Author: | sandy in BC [ Sun Oct 10, 2010 8:08 am ] |
Dennis' version of finger tight = 150ft/lbs........ |
