It is currently Sat Oct 10, 2026 11:10 pm
PostPosted: Tue Sep 24, 2002 6:06 am
...to fit the end of a 1970 slant six crankshaft? The big one to put in to install the balancer or use to turn the engine. I will need to go get one. Thanks.
vze28st5@verizon.net
PostPosted: Tue Sep 24, 2002 9:05 am
The thread size is 3/4-16.
3/4" diameter, 16 threads per inch. I don't have a length to tell you but you should be able to figure that out.
cfield@ll.net
PostPosted: Tue Sep 24, 2002 9:19 am
: The thread size is 3/4-16.
: 3/4" diameter, 16 threads per inch. I
: don't have a length to tell you but you
: should be able to figure that out.
Many thanks. Never had to get one before and unfortunately I do not own a V-8 Mopar to borrow one from. :)
PostPosted: Tue Sep 24, 2002 11:34 am
Hold on...3/4 inch? As in 3/4 inch diameter shaft? That sounds awfully big...
PostPosted: Tue Sep 24, 2002 12:40 pm
Vibration Dampener Bolt 3/4-16 UNF, 2.3 inches long total.(1.5 Min. thread area)
It will also need a big thick washer.
PostPosted: Tue Sep 24, 2002 2:08 pm
: Vibration Dampener Bolt 3/4-16 UNF, 2.3 inches
: long total.(1.5 Min. thread area)
: It will also need a big thick washer.
: DD
Wow, that is one huge bolt. Thank you for the missing spec.
Users browsing this forum: Amazon [Bot], Google [Bot] and 24 guests
