engine shudders between 1500 and 2000 rpm
https://slantsix.org/forum/viewtopic.php?t=42206
Author:  saskatchewan [ Sun Oct 10, 2010 7:09 am ]
Post subject:  engine shudders between 1500 and 2000 rpm
Hi
Yesterday my engine (225 hyperpack) started to shudder between 1500 and 2000 rpm. But only in that rpm range. I was thinking it might be a fouled plug or plug wire, or maybe a vacuum leak.
Any ideas?
Author:  wjajr [ Sun Oct 10, 2010 3:36 pm ]
What was the air temperature the day the car was stuttering?
Do you have provisions for carburetor heat with that hyper pack? If temperatures were in the 40’s F or lower you maybe forming carburetor ice. When ice forms, idle & low rpm operation becomes rough, and fuel mileage drops like a rock.
I had a like problem with my unheated Clifford manifold, and had to build a hydronic hot spot under the carburetor, feed by cutting into the heater loop. Drivability came right back during cool & cold weather once it was installed.
Author:  saskatchewan [ Sun Oct 10, 2010 8:27 pm ]
Yes, I have the offenhauser manifold with a front dutra dual and the rear manifold provides heat for the manifold.
I tried cleaning up the carb and plug connections and things cleared up. I think that my kickdown was just sticky.
Thanks for the reply.
