| Gear drive for timing https://slantsix.org/forum/viewtopic.php?t=42214 |
| Author: | dustertech2000 [ Sun Oct 10, 2010 6:35 pm ] |
| Post subject: | Gear drive for timing |
has anyone ever come across a gear drive for a slant, i'm going to be taking apart enging again and would like one. |
| Author: | ceej [ Sun Oct 10, 2010 7:08 pm ] |
Take a listen before you decide.. Timing accuracy is not necessarily as good as a quality chain. Looks like Pentastar in Australia discontinued them. CJ |
| Author: | dustertech2000 [ Sun Oct 10, 2010 7:18 pm ] |
yeah i love that loud whine they make. |
| Author: | 66aCUDA [ Tue Oct 12, 2010 7:06 am ] |
Quote: yeah i love that loud whine they make.
Run a Blower Frank |
| Author: | dustertech2000 [ Tue Oct 12, 2010 6:22 pm ] |
ha i would love to just a little pricey. |
| Author: | Wizard [ Tue Oct 12, 2010 7:10 pm ] |
| Post subject: | Gear noise causes? |
Won't the gear teeth form and mesh depth influence the gear noise? Hint: transmissions usually doesn't whine, rear end don't howl if badly worn or mis-meshed. Cheers, Wizard |
| Author: | slantzilla [ Tue Oct 12, 2010 7:17 pm ] |
As a general rule, straight cut gears are much noisier than angle cut gears. I had a B&M straight gear drive in a Chevy pickup. At 60 on the tollway it closely resembled the whine from a jet engine. |
| Author: | madmax/6 [ Tue Oct 12, 2010 8:01 pm ] |
If ya want an on-going whine noise, I will give you my ex wife's number. |
| Author: | slantzilla [ Wed Oct 13, 2010 6:40 pm ] |
Quote: If ya want an on-going whine noise, I will give you my ex wife's number.
| Author: | Team Green [ Sun Oct 17, 2010 8:03 am ] |
Big block MoPar, big block Chevy and the slant have the same camshaft to crankshaft centerline. The crank snout is also the same diameter as the big block MoPar. Hope this helps. |
