It is currently Mon Nov 23, 2026 3:19 pm
 Post subject: Hardened Valve Seats
PostPosted: Mon Oct 11, 2010 10:39 am
In conjunction with my triple Weber engine build, I plan on using the engnbldr S/S valves and 340 springs in a spare drool tube head (early 70s vintage) I have. I just off the phone with my machinist and he was wondering whether there's sufficient room for both new hardened seats plus the oversize exhaust valves. He was thinking out loud as it's been ages since he's done a slant head. I did some searching on this and it appears there's no problems with this. For those of you who have used the engnbldr valves, what was your machinist using for the hardened seats. If you have a part number or any other info, that would be helpful. My valves from engnbldr also included a set of bronze guides. I understand they would be better to use than the original iron guides. Any comments there?
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Mon Oct 11, 2010 10:46 am
My under standing is that the iron guides wear longer/better that the bronze guides-has to due with the free carbide in the iron.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Mon Oct 11, 2010 11:23 am
Hardened valve seats are for the exhaust valve seats only, the intake valves do fine with the seat ground onto the head's cast iron... just open those up to the larger valve size.
PostPosted: Mon Oct 11, 2010 1:28 pm
Yes am aware of that.
Yes, am aware of that as well. Just trying to determine if there will be a problem with larger hardened seats with the larger exhaust valves as well as room for everything. Don't think so; just verifying. Anybody with a seat number to use with the larger exhaust valves?
PostPosted: Mon Oct 11, 2010 1:55 pm
I got confused when I read "both new hardened seats"...
Anyway, most hardened Valve seat inserts are made by Dura-Bond, now a part of Melling.
There are many sizes to choose from but in general, try to stay close to the valve OD and keep the thickness as thin as possible, so you don't hit water when machining / installing the inserts.
The 31159 / 71159 or the 30556 / 70556 are a good starting point for review.
Here is a link to the catalog:
http://www.melling.com/LinkClick.aspx?f ... &tabid=632
PostPosted: Mon Oct 11, 2010 2:19 pm
I just had some hardened exh seats put in a head for the 1.44 engnbldr valves. I've done this on heads up to 1.50 exh valves with no problem.
PostPosted: Mon Oct 11, 2010 5:09 pm
My machine shop mistakenly installed hardened seats on both intake and exhaust ( 1.72 intake 1.50 exhaust) Worked fine.
PostPosted: Mon Oct 11, 2010 6:09 pm
Lou - any chance of checking with your machine shop guy on what they used for the exh seats?
