Standard Pushrods, How strong are they?
https://slantsix.org/forum/viewtopic.php?t=42218
Page 1 of 1
Author:  62hypapak [ Mon Oct 11, 2010 4:51 am ]
Post subject:  Standard Pushrods, How strong are they?
Im building a long rod hyper pak with double valve springs with a 364" lift cam, should a get a set of moly rods made up?
Should I stay the standard size if I get them made up?
In the near future I'll also be planning on installing 1.5 ratio rollar rockers.
Author:  THOR [ Mon Oct 11, 2010 8:14 am ]
Awesome! Just FYI, Standard rockers are 1.5:1 too.
What are your Cam specifications?
So long as the pushrods are spinning while the engine is running, standard pushrods should be fine. I've never heard of molybdenum pushrods, but I do know There are a few after-market units available. The Cox brothers come to mind.
~RDE~
Author:  Joshie225 [ Mon Oct 11, 2010 8:54 am ]
Usually the stock pushrods are replaced because of length issues. Getting a decent compression ratio with standard pistons requires significant hand and/or block milling and the stock pushrods end up being too long. Smith Brothers can provide just about anything you might need for good prices and with excellent service. http://www.pushrods.net/
One more thing. True dual valve springs are rarely needed with a 225 as they just don't spin that fast. The HP single spring with the flat damper as used in 340s is usually plenty. If you want to spend money you can use beehive springs and their little retainers. I'm doing this for a high RPM 170 engine.
Author:  DusterIdiot [ Mon Oct 11, 2010 7:48 pm ]
Post subject:  Fyi...
Unless you specify something more exotic, Smith Brothers rods are Moly standard... On my last two hi-po builds I had to order a custom length
due to the cut off the head and deck. Cut a stocker rod about 2 inches from the cup and take out a 1/2" chunk...thread the inners and install a piece of 1/4" all thread and nuts on each end...this makes an adjustable length pushrod to check your rocker geometry and see what the true length needs to be (you can lock the nuts and send it to Smith Brothers and they'll make a set off that length and ends)...
Having bent two stock rods due to being too long and having cut almost a 1/4" off the last mill, I also opted to have the rods made at 3/8" and for a thicker than stock wall (.063...they can make it thicker, but .063 is all that is needed we don't use springs with massive seat pressure...)
