low volume of oil to rockers
https://slantsix.org/forum/viewtopic.php?t=42220
Author:  THOR [ Mon Oct 11, 2010 9:13 am ]
Post subject:  low volume of oil to rockers
Since installing the new Cam (kept the bearings) and pump, I've noticed that I really don't get much oil to the rockers, not like I've seen on most others.
If I rev to over 2k I seem to get decent flow, but even then, it seems like there should be more.
I was very careful in swapping cams, and I know the bearings are good. I oiled down the feed hole for the rocker shaft prior to starting.
Is there something else I should check?
~RDE~
Author:  Doc [ Mon Oct 11, 2010 10:06 am ]
Is the rocker shaft installed correctly so the oil feed holes line-up w/ the rocker arm oil holes?
Did you check the cam's oil feed cross hole for correct oreantation?
These can be mis-drilled in the cam and that reduces the amount of flow to the rocker-arms.
The other possibility is that the rear cam bearing is not installed correctly or has rotated, blocking / partially blocking the feed oil holes.
Author:  DusterIdiot [ Mon Oct 11, 2010 7:53 pm ]
Post subject:  Hmmm...
He's using a cam I had used in the BV build.
The holes are drilled correctly. With this cam I did use a Rollmaster timing chain and a Doc Dodge Cam Button (TM)....I wonder if the cam with his silent chain has moved the cam and oiling hole a sukoshi causing a slight restriction...
