| Shift cables https://slantsix.org/forum/viewtopic.php?t=42225 |
| Author: | lancer61 [ Mon Oct 11, 2010 12:04 pm ] |
| Post subject: | Shift cables |
I bought a 1965 904 tranny and now I need to find a shift cable for it, but there are different shift cables available, column shift and console shift, are those cables different in any other way then the length of the cable ? |
| Author: | bigslant6fan [ Mon Oct 11, 2010 9:28 pm ] |
| Post subject: | - |
I don't know too much about pre-67 transmissions,but I think the valve body in the trans was even different,push button vs steering column or consol shift. |
| Author: | Fopar [ Mon Oct 11, 2010 10:25 pm ] |
I don't think the valve bodies are different, maybe just the cables Does the transmission have any arms or levers on the exterior? Richard |
| Author: | Doc [ Tue Oct 12, 2010 9:00 am ] |
The transmission & valve body is the same (65 only, 6 detent positions) but the cables / linkage is different. (the shifter mounting ends change) Cables made for one assembly can not be used on the other. What is your need... cables for a 65 column? DD
| Author: | VDART [ Tue Oct 12, 2010 8:46 pm ] |
someone is selling a 65 tranny at FABO---- maybe they would sell you just the cables ,Lawrence |
