It is currently Sun Nov 22, 2026 8:43 pm
 Post subject: distributor ID
PostPosted: Fri Oct 15, 2010 11:04 am
Just want to double check before I sell this. 3874876 should be for a 78 super 6,thanks
PostPosted: Fri Oct 15, 2010 1:27 pm
Also '79; all 1 and 2 barrel.
Federal: with catalyst only, and with catalyst and air pump
Canada: with catalyst only
I think I read somewhere that this distributor was used from '74 -> '80, on all non lean burn, and non-california models.
Olaf
Aspenized
 Post subject: No and yes...
PostPosted: Fri Oct 15, 2010 8:02 pm
1973-1974 uses similar 15R distributors
1976 you get a choice depending on options for an 11R or 9R governor
1978+ you get the 3874876 for super six...and eventually it replaces the distributor in some 1 barrel models as well...(except for trucks)
If you are going to do a recurve, this is a desired core to build from...
 Post subject: -
PostPosted: Fri Oct 15, 2010 10:14 pm
Thanks gentlemen,I sold this under the reprensentation in was from a '78 super 6,but I just wanted to be sure.
Users browsing this forum: Google [Bot] and 11 guests
