| distributor ID https://slantsix.org/forum/viewtopic.php?t=42272 |
| Author: | bigslant6fan [ Fri Oct 15, 2010 11:04 am ] |
| Post subject: | distributor ID |
Just want to double check before I sell this. 3874876 should be for a 78 super 6,thanks |
| Author: | olafla [ Fri Oct 15, 2010 1:27 pm ] |
Also '79; all 1 and 2 barrel. Federal: with catalyst only, and with catalyst and air pump Canada: with catalyst only I think I read somewhere that this distributor was used from '74 -> '80, on all non lean burn, and non-california models. Olaf |
| Author: | DusterIdiot [ Fri Oct 15, 2010 8:02 pm ] |
| Post subject: | No and yes... |
Quote: I think I read somewhere that this distributor was used from '74 -> '80, on all non lean burn, and non-california models.
1973-1974 uses similar 15R distributors1976 you get a choice depending on options for an 11R or 9R governor 1978+ you get the 3874876 for super six...and eventually it replaces the distributor in some 1 barrel models as well...(except for trucks) If you are going to do a recurve, this is a desired core to build from... -D.Idiot |
| Author: | bigslant6fan [ Fri Oct 15, 2010 10:14 pm ] |
| Post subject: | - |
Thanks gentlemen,I sold this under the reprensentation in was from a '78 super 6,but I just wanted to be sure. |
