Over heating
https://slantsix.org/forum/viewtopic.php?t=42301
Author:  B200Bill [ Sun Oct 17, 2010 4:08 pm ]
Post subject:  Over heating
My van overheats when I am on the freeway for more than 15 minutes. At that time the temp is gradually raising. But when I get off the freeway it starts cooling down and is in normal range in a few minutes.
This happens when the outside temperature is over 80 degrees. On cool days this is not a problem.
Is this a radiator or water pump problem? Or something else?
Author:  emsvitil [ Sun Oct 17, 2010 10:34 pm ]
Clogged radiator or thermostat isn't opening enough.
Take out the thermostat and see what happens. (test in boiling water while you're at it)
