It is currently Sun Jun 21, 2026 8:52 am
 Post subject: Could ebay be wrong???!!
PostPosted: Wed Oct 20, 2010 4:19 pm
This doesn't look like a 67 idler arm, does it? They are usually very expensive.
Don't look right.
PostPosted: Wed Oct 20, 2010 5:29 pm
That would be a pitman arm ..........available everywhere. Fits thousands of mopars :lol:
MaX
PostPosted: Wed Oct 20, 2010 5:30 pm
Did a search of a local site I like to use
http://www.pentastarparts.com.au/sunsho ... =idler+arm
I didn't think it was an idler arm, for a 67 A body but I could be wrong, world is upside down here in aus land.
 Post subject: 67-72-retract
PostPosted: Wed Oct 20, 2010 8:49 pm
That is a 1967-1972 pitman arm where the arm comes under the centerlink, they are about that cheap over the counter most parts
stores. The 1973-1976 is different as the link stud is the opposite
in direction since the stud passes through the top of the link, not from below it.
Boy must've been tired, that is the idler arm...pitman arm has the knurled "o" on the other end to fit the steering sector shaft...
Think I need to spend some more time under the car than under the hood!
:oops:
PostPosted: Thu Oct 21, 2010 2:43 pm
Right, a pitman arm, it looked familiar but wrong. Slightly used. Still no bidders.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Fri Oct 22, 2010 6:56 am
Online
Looks to me to be a '68-72 idler arm. The '67 was still on it's own bracket/stud like a '66 right? :shock:
PostPosted: Sat Oct 23, 2010 7:47 am
The '67 has two ball-in-socket joints with the studs pointing down. There is a picture of the 68-up idler arm in the $Yearone$ catalog that supports Slantzilla's ID.
