| bought nos rocker arms and too tight on shaft https://slantsix.org/forum/viewtopic.php?t=42385 |
| Author: | SCOTT EVIL [ Mon Oct 25, 2010 1:09 pm ] |
| Post subject: | bought nos rocker arms and too tight on shaft |
So I wanted to play with reducing some valve train noise and bought new old stock rocker arms. I found that they wont or barely fit onto the rocker shaft. I guess the right way will be to take them to a machine shop and have them sized to the rocker shaft. But, had to ask this silly question. Could it be as simple as using a brake cylinder hone to get them to fit? Or would this backyard mechanic attempt wipe out the rocker shaft due to a poor finish inside the rockers? My next trick is installing the offenhauser dual single carbs on it. I like the abuse i guess. Thanks, Glen |
| Author: | Doc [ Mon Oct 25, 2010 3:13 pm ] |
Measure your shaft to be sure it is round. I have seen a number of rocker shafts "smashed" oval, at the bolt holes... from being over-tightened. DD |
| Author: | SCOTT EVIL [ Mon Oct 25, 2010 3:21 pm ] |
| Post subject: | where to buy a new rocker shaft ? |
Wow, what a great tip. You are correct as the rocker gets "tight" at the holes for the bolts. I have tried Napa and Autozone, but neither can get a new rocker shaft. Do you know who sells them ? Thank you for sharing your experience and skill. Wow. |
| Author: | Charrlie_S [ Mon Oct 25, 2010 5:00 pm ] |
Rock Auto Parts can get them, as can Summit Racing http://www.summitracing.com/search/?key ... -620&dds=1 |
