| Dipstick https://slantsix.org/forum/viewtopic.php?t=42400 |
| Author: | 60 Plymouth [ Tue Oct 26, 2010 6:21 am ] |
| Post subject: | Dipstick |
Hi all, Looking for a dipstick for a 1960 A-904. I believe the parts exchange from 1960-66, I think one of the Doc's posts elsewhere on this forum stated this. I've put an ad on here but had no luck, so does anyone know where I can get one new? Alternatively, if anybody could give me all the necessary dimensions to make one, then I'd happily do so. Thanks a lot, 60 Ply |
| Author: | VOLOVICK [ Tue Oct 26, 2010 2:53 pm ] |
BELIVE IT OR NOT I GOT ONE FOR MY 63 VALIANT FROM THE PART DEPARTMENT AT THE DEALER. About two week ago |
| Author: | Wizard [ Tue Oct 26, 2010 3:31 pm ] |
That is strange, back housing of the water pump for carbed 2.2L is NLA since 2003 and I needed one. Not the other half that contains rotating pump. So I'm modifying a TBI water pump to clear the fuel pump so I have caravan drivable for awhile. Once I have the pump out, crack in radiator nipple will be repaired. Housing is aluminum and is weldable. Cheers, Wizard |
| Author: | Doc [ Tue Oct 26, 2010 3:41 pm ] |
I have a few used ones... if it comes down to that. DD |
| Author: | 60 Plymouth [ Mon Nov 01, 2010 7:12 am ] |
Hi Guys, Thanks for the replies. Doc, very interested: you have a PM. All the best, 60 Ply |
| Author: | 60 Plymouth [ Fri Nov 19, 2010 3:51 am ] |
Anybody have a part number for the 1960-66 torqueflite dipstick? I might have more luck with the chrysler dealer if I can give them a number. Thanks a lot, 60 Ply |
| Author: | Charrlie_S [ Fri Nov 19, 2010 5:23 am ] |
Part number for a 66 904 filler tube is 2538 834. for the stick it is 2466 302. Unable to locate filler tube, located stick at these dealers. http://www.bradsnosparts.com/ http://collectorsautosupply.com/ http://www.dpmotorparts.com/ I have not purchased from any of these vendors. |
| Author: | 60 Plymouth [ Fri Nov 19, 2010 5:30 am ] |
Hi Charrlie, Thanks for the response. Don't suppose you know the p/n for the 1960 version do you? I think 66+ was different (a few cross references seem to agree). |
| Author: | Charrlie_S [ Fri Nov 19, 2010 6:35 am ] |
Quote: Hi Charrlie,
Sorry, I only have parts manual for 1966,67,68,69.
