| hello new here https://slantsix.org/forum/viewtopic.php?t=42468 |
| Author: | droptheworld [ Mon Nov 01, 2010 11:18 pm ] |
| Post subject: | hello new here |
hello i own a 72 demon /6, carter 1 bbl nothing fancy,my exhaust manifold crack 2 days ago,i need to replace it fast,i have a super six air cleaner,carter bbd,intake,exhaust,and NO LINKAGE is not in top shape litle tire ill say,would like to learn how the linkage works ?,i dont drive much,o almost forgot i replace the oem carb choke for an electric choke donno know the part # but it cost like $50 bucks i would like to use it if i dont go the super six way i believe it wont work with the carter carb linkage, thank in advace great site |
| Author: | Eric W [ Tue Nov 02, 2010 5:00 am ] |
A '72 manifold...that means you have a choke "pocket" that is basicly a hole in the manifold a cup sets into and the choke thermostat goes on top of correct? If you use a later manfold that was used with a super six with your one barrel carb you will need to get an electric choke thermostat for a '73 - '74 225 with a Holley one barrel. I found a choke thermostat years ago from JC Whitney (of all places) when I did a simular manifold swap in my old '72 Satellite. If you go this route, you will also need to wire the choke into a keyed electrical source, and also need a little resister that goes in line with the wiring. Let us know and we can help you out. |
| Author: | droptheworld [ Tue Nov 02, 2010 11:16 am ] |
ty eric for sharing the difference on the manifolds to others,well my holley carb was rebuilt about a 6 months is tired, getting a new choke to work with my 78/79 manifold dont seen like a big problem(i do have the 2bbl choke), but i will like to retired my 1bbl asap i had some problems with the 1bbl, super six 2bbl carter is ready to go in i dont have the funds for a linkage from a third party so my only hope is yunk yards which i love,thx |
| Author: | olafla [ Tue Nov 02, 2010 8:33 pm ] |
Hi droptheworld, and welcome to the forum! Take a look as this link from a member with parts for sale. Send him a pm about the things you need, price is probably lower than in the store! Olaf. |
