What year?
https://slantsix.org/forum/viewtopic.php?t=42486
Author:  marineviper [ Wed Nov 03, 2010 7:55 pm ]
Post subject:  What year?
What year did the head change so you have to remove it to get the lifter out??? I have an 80.
Author:  Joshie225 [ Wed Nov 03, 2010 8:08 pm ]
The head changed in '75. The loss of spark plug tubes meat the loss of easy access to the lifters.
Author:  kesteb [ Wed Nov 03, 2010 10:56 pm ]
Not so, you should be able to remove the lifters without removing the head with a '80 or later head.
Author:  Fopar [ Thu Nov 04, 2010 12:03 am ]
Kevin that isn't going to work the lifters are much larger than the push rod holes in the head. :roll: :tsk: :lol:
Richard
Author:  Dart270 [ Thu Nov 04, 2010 8:11 am ]
I believe '81 was the latest (hydro) head with larger pushrod holes, just bigger than lifters. '76-81 was one with small pushrod holes and no drool tubes.
Author:  kesteb [ Fri Nov 05, 2010 11:33 pm ]
I have an '80 head seating on the floor that you can slip the lifters thru. The '79 head that is currently on my engine you can not.
