It is currently Sun Nov 22, 2026 4:51 am
 Post subject: Quick 198 question
PostPosted: Wed Nov 24, 2010 6:51 pm
Just double checking:
Installing a 198 crank/rod combo into a 225 block makes it a 198 right? It will fit with no modification?
Wanting to build a 198 in the future.
Thanks :D
PostPosted: Wed Nov 24, 2010 7:01 pm
AFAIK yes, that's the only difference. What you could do is take those 198 rods and stick them on a 225 crank, then you would have a long rod 225.
~RDE~
PostPosted: Wed Nov 24, 2010 7:13 pm
Yep, crank and rods are the only difference between a 198 and a 225. I bought a remanufactured 198 short block a while back. I sold the rods and crank out of it. I used the money to rebuild some 225 rods with ARP bolts, and polish a 225 crank.
PostPosted: Wed Nov 24, 2010 8:02 pm
Thanks guys,thats what I thought.
THOR- I know about the long rod motor. But I want to build a 198 for my future turbo build. Im liking the 1.92 R/S ratio,and shorter stroke for winding it up.
