It is currently Sat Nov 21, 2026 7:46 am
PostPosted: Mon Nov 15, 2010 2:28 pm
I picked up a "225" in a trade so it wouldn't get recycled and assumed the guy knew what he had, turns out it's a 170. So I was thinking of what use this thing could be to me and wanted to know more about it. My plans are either a bucket style rat rod or a front engine drag car, something fairly simple.
I didn't realize what I had until I looked at "the hose", you know that 1" excuse for a coolant hose. Either way give me what ever specs or facts or even ideas you may have about this thing.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Mon Nov 15, 2010 2:53 pm
I plan on cranking my race 170 to 8000 RPM. Wish me luck! 7000 RPM with good valve springs and rod bolts isn't too tough. Regardless the weak link is still the oil pump gear.
I've always liked the looks of a Track-T. It might be tough to keep it all under the hood, but it would be fun to try. http://www.speedwaymotors.com/Speedway- ... ,4010.html
If you and I were a little closer I'd ask if you want to sell the engine as I'm looking for another 170 core or at least a good crank.
PostPosted: Mon Nov 15, 2010 3:05 pm
Do most of the 225 parts swap? Three main things are the crank rods and block right? What about the head, are the valves way smaller? Can the head be worked for a spare 225 head?
, Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Mon Nov 15, 2010 3:27 pm
The cylinder heads are identical year-for-year. The issue though is most 170s are '66 and older with the old style combustion chamber. Check the casting number. Read the article if you haven't. http://www.slantsix.org/articles/combus ... hamber.htm
Block, crank, con rods, pushrods, and cam grind are 170 specific. 170s generally had a somewhat smaller carb and early ones allegedly had a cam sprocket to advance the cam timing. I can't recall any other differences. Oh, the distributor advance curve is probably a little different.
PostPosted: Mon Nov 15, 2010 3:38 pm
Alright Josh thanks for your help.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
