bronze vs hardened oil pump gear?
https://slantsix.org/forum/viewtopic.php?t=42587
Author:  62hypapak [ Mon Nov 15, 2010 2:11 am ]
Post subject:  bronze vs hardened oil pump gear?
so which one is for each application??
whats the difference?
Author:  66aCUDA [ Mon Nov 15, 2010 5:50 am ]
Bronze one was for the Aussie "Hemi" six. Iron only for the slant.
As far as I know.
Frank
Author:  Doc [ Mon Nov 15, 2010 9:24 am ]
I made-up a batch of bronze (really a nickel-bronze alloy) SL6 oil pump gears for use with steel camshafts. (roller cam applications)
An iron gear wears-out fast when use with a steel cam.
I also heat treat (carborize) the factory cast iron gears to give them a harder "skin". (case hardening)
Author:  62hypapak [ Tue Nov 16, 2010 4:39 am ]
Would you recommend getting the stock gear hardened and pressing it on a key way melling kit, is this bad practice? Or get the key way gear case hardened?
Author:  66aCUDA [ Tue Nov 16, 2010 6:01 am ]
Ahh ok didnt know your made a batch Doug.
Frank
Author:  Doc [ Tue Nov 16, 2010 10:32 am ]
Either way works better then using the gear that came on the new Melling pump.
I can provide both types of gear, if needed.
(Heat treated factory or aftermarket gears, with a keyway slot)
