It is currently Mon Nov 16, 2026 12:02 pm
 Post subject: adjusting bands in a 727
PostPosted: Tue Nov 16, 2010 4:10 pm
i have a early ramcharger with the 225 and 727+4x4.how do i adjust all the bands in it? i cant read the manual on the site its messed up at that part.
thnks jimbo
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Wed Nov 17, 2010 1:06 am
Kickdownband
Loosen lock not five turns,
Tighten band adjusting screw to 72 inch pounds,
Back of screw 2 turns,
Lock nut (25 foot punds),
Low/Reverse band
Tighten band ajusting screw to 72 inch pounds
Back of screw 5 1/4 turn,
Lock nut (25 foor pounds),
That is from a 904 manual, if I am correct the only difference for a 727 is
that you should should loosen the screw for low/reverse band 2 turns instead of 5 1/4.
Please correct me if I am wrong here
Users browsing this forum: Amazon [Bot] and 5 guests
