Grooving lifters
https://slantsix.org/forum/viewtopic.php?t=42636
Author:  stonethk [ Sat Nov 20, 2010 9:11 am ]
Post subject:  Grooving lifters
Just a thought. Has anyone done this for more oil flow? Thinking more for a high revving engine.
Author:  Shaker223 [ Sat Nov 20, 2010 9:30 am ]
Groove the nonthrust side of the lifter bore instead.
Author:  madmax/6 [ Sat Nov 20, 2010 9:51 am ]
I filed some grooves in the down side of my lifter bores,not real deep but enough in theory to get some extra oil around them.Guzzi Mark
Author:  DusterIdiot [ Sat Nov 20, 2010 10:04 am ]
Post subject:  Not yet but...
For awhile I've been looking at the grooving tool that Comp sells, might experiment with a file or make a tool out of a used lifter and a nitride drill bit.
The procedure can't hurt as long as you follow the advice above inthe post, and I would add a tall bushing in the lifter valley drain holes so you have a standing reserve of oil.
Author:  Joshie225 [ Sat Nov 20, 2010 10:05 am ]
I'm planning on running 8000 RPM and I'm not worried about the lifters. If the lifters were pressure fed and I was worried about the cam to lifter interface I'd buy lifters with the tiny EDM hole in the face. Since all we have is gravity I think the groove in the lifter bore would have to be appropriately sized. If you have dumbbell lifters they hold an oil supply which helps the lifter, but does nothing for the cam.
