It is currently Sun Nov 22, 2026 2:24 am
 Post subject: Cam stops
PostPosted: Tue Nov 23, 2010 6:55 am
Does anyone have any pictures? What are the advantages? Should they be instaled in a long rod slant?
PostPosted: Tue Nov 23, 2010 8:29 am
I use cam stops on all the engines I build... it is an easy way to ensure that the cam stays where you want it.
PostPosted: Tue Nov 23, 2010 10:33 am
Doc,
What is the best way to adjust it?
Do you have a gap measurement?
or it screwed down snug? tight?
How do you know when it is set correctly?
PostPosted: Tue Nov 23, 2010 11:26 am
It is easy to adjust when building the engine. (oil pan is off)
Install the cam, timing set & cover, then push the cam "back & forward" while adjusting the ballscrew... until all the clearance (movement) goes away, then back off the screw a 1/4 turn and lock it down, with the lock-nut.
If done correctly, you will feel the slightest amount of clearance, much like adjusting the axle bearing end-play on an 8 3/4 rear end.
PostPosted: Tue Nov 23, 2010 11:40 am
I have always thougth that the cam bolt was tigth until zero movement was achieved, when you backoff the ballscrew 1/4 turn why you do that?
Once you cancel the movement on the cam and you have the oil pump gear ok with the cam I always thougth that there was no reason to give the cam any movement at all.
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Tue Nov 23, 2010 11:46 am
Friction and wear on ball.
PostPosted: Tue Nov 23, 2010 11:48 am
Clearance is needed.Otherwise the adjuster will be in constant contact with the cam.
PostPosted: Tue Nov 23, 2010 12:08 pm
And for that here they put bronze in the tip of the bolt, or they even use a rocker adjuster. For both is OK to run zero clearence I think.
Martin Zappettini
PostPosted: Tue Nov 23, 2010 12:42 pm
I do mine like Doc said,then fine tune after motor is broke in.lets the cam and gears settle to be where they want to bee.While the motor is running I screw it in till it just touches,then back it off a titch.Mark
PostPosted: Tue Nov 23, 2010 1:38 pm
Is that the screw out of a mechanical rocker arm?
PostPosted: Tue Nov 23, 2010 1:56 pm
6 Pack Dart
YES
Richard
PostPosted: Tue Nov 23, 2010 2:50 pm
Sweet. I always wondered how Doc did that.
PostPosted: Tue Nov 23, 2010 3:49 pm
If there is no clearance it will wear a cup in the head of the cam bolt.
PostPosted: Tue Nov 23, 2010 4:09 pm
Last time I did this I had access to a lathe so I faced off the cam sprocket bolt and the rocker screw so they came together flat.
PostPosted: Tue Nov 23, 2010 5:49 pm
I drilled a little cup in the center of the bolt.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 9 guests
