It is currently Sat Nov 21, 2026 3:24 pm
PostPosted: Fri Nov 26, 2010 4:50 pm
Well my factory steering wheel is cracked and is killing my hands, so I want to swap it out with a Grant Wheel. I have the adaptor kit, so it is ready to be installed.
My question is, how do I get to the bolts to take off the steering wheel?
I already have a wheel puller, so I am ready to go, but I figured I would ask this question before I tackle this job tommorow.
By the way I am doing this on a 65 belvedere II.
Thanks!!
1965 Plymouth Belvedere II- Project Car
1992 Mitsubishi 3000gt VR4- Show Car
2004 Chevrolet Corvette- Daily Driver
PostPosted: Sat Nov 27, 2010 5:56 am
most of those early 60's style either have a center piece that snaps in place or twists in place..
try twisting your center piece counter clockwise, if that removes it then the screws will be obvious.
valiants/darts needed to be pryed up carefully-- they were press fit in with a rubber seal/spacer.
try the twist 1st-- then carefully pry-- or you will chip/brake your item, Lawrence
PostPosted: Sun Nov 28, 2010 2:04 am
There are two threaded holes, one on each side of the center axle so that you can fit a puller.
