170 rods. Stock and not.
https://slantsix.org/forum/viewtopic.php?t=42703
Author:  Joshie225 [ Fri Nov 26, 2010 4:45 pm ]
Post subject:  170 rods. Stock and not.
The stocker is 5.70" center to center. The pretty rod is 6.00" C-C. What do you thing the weight difference is?
BTW, the next race 170 will use the rod on the right with a 1.25" CD piston, maybe an off the shelf Neon piston. The pin is the right size.
Crud, forgot the picture!
Author:  ceej [ Fri Nov 26, 2010 4:51 pm ]
Before answering, what material is the "pretty" rod? :lol:
CJ
Author:  Joshie225 [ Fri Nov 26, 2010 4:56 pm ]
CJ
Some fancy kinda steel.
Author:  Fopar [ Fri Nov 26, 2010 5:04 pm ]
Is it an H beam ?
Author:  ceej [ Fri Nov 26, 2010 6:43 pm ]
OK, Mine were 240 Grams lighter than stock, so I tossed 250 up there. Those are even cleaner than the ones I had worked up for the hooptie! :D
CJ
Author:  Joshie225 [ Fri Nov 26, 2010 8:15 pm ]
Is it an H beam ?
Yes. It's also got a little hole the length of the rod to oil the pin.
Author:  madmax/6 [ Fri Nov 26, 2010 9:40 pm ]
248.77 lighter.could get closer with better pics.Wilfred
