| Steering wheel Removal- 65 Belvedere https://slantsix.org/forum/viewtopic.php?t=42704 |
| Author: | Theo VR4 [ Fri Nov 26, 2010 4:50 pm ] |
| Post subject: | Steering wheel Removal- 65 Belvedere |
Well my factory steering wheel is cracked and is killing my hands, so I want to swap it out with a Grant Wheel. I have the adaptor kit, so it is ready to be installed. My question is, how do I get to the bolts to take off the steering wheel? I already have a wheel puller, so I am ready to go, but I figured I would ask this question before I tackle this job tommorow. By the way I am doing this on a 65 belvedere II. Thanks!! |
| Author: | VDART [ Sat Nov 27, 2010 5:56 am ] |
most of those early 60's style either have a center piece that snaps in place or twists in place.. try twisting your center piece counter clockwise, if that removes it then the screws will be obvious. valiants/darts needed to be pryed up carefully-- they were press fit in with a rubber seal/spacer. try the twist 1st-- then carefully pry-- or you will chip/brake your item, Lawrence |
| Author: | lancer61 [ Sun Nov 28, 2010 2:04 am ] |
There are two threaded holes, one on each side of the center axle so that you can fit a puller. |
