Richer or leaner in the cold??
https://slantsix.org/forum/viewtopic.php?t=42705
Author:  madmax/6 [ Fri Nov 26, 2010 6:59 pm ]
Post subject:  Richer or leaner in the cold??
Going to go out and start running my car again,wondering if they want more or less jet in cooler weather.Had it pretty much dialed in for 80 to 95 degrees out.Will now bee running at about 60 degrees,I think a little more jet??Thoughts???Mark
Author:  Fopar [ Fri Nov 26, 2010 7:54 pm ]
Cooler air is more dense, so it would be like going from higher elevation to sea level.
Richard
Author:  Joshie225 [ Fri Nov 26, 2010 8:13 pm ]
Yep, more air molecules will allow you to burn more fuel molecules.
Author:  madmax/6 [ Fri Nov 26, 2010 9:43 pm ]
So colder fatter correct? mark
Author:  Aggressive Ted [ Fri Nov 26, 2010 10:09 pm ]
Yes!!!!!
Author:  Fopar [ Fri Nov 26, 2010 11:18 pm ]
Mark just don't go ape just a little bit more.
Richard
