| Distributor O ring? https://slantsix.org/forum/viewtopic.php?t=42708 |
| Author: | Sam Powell [ Sat Nov 27, 2010 5:00 am ] |
| Post subject: | Distributor O ring? |
Does anybody know the specs on the O ring that goes on the distributor shaft housing? I was going to go to the auto store and just look through their assortment. But, they are dimensioned, and if I knew what size was called for, I could look at those specs on the plastic envelope they come in. Thanks. Sam |
| Author: | emsvitil [ Sat Nov 27, 2010 5:43 pm ] |
I just used one from the large assortment from Harbor Freight...... |
| Author: | Sam Powell [ Sat Nov 27, 2010 7:44 pm ] |
I guess I should buy that assortment. There is a retail Harbor Freight locally here. I will check them out. Sam |
| Author: | emsvitil [ Sat Nov 27, 2010 7:48 pm ] |
Look in newspapers and magazines for the 20% off coupon and a freebie..... Print off the online price, if it's cheaper than the store price they'll give you the online price (at least they do in CA) |
| Author: | Sam Powell [ Sat Nov 27, 2010 8:52 pm ] |
I have been behind customs at the counter at Harbor Freight who have done that. It seems to help if the customer is a pretty girl. I am neither. But, I will give it a try. Sam |
| Author: | 66aCUDA [ Sun Nov 28, 2010 6:27 am ] |
Hey Sam Maybe the cashier will be the Pretty Girl. We certainly have some at our stores here. Frank |
| Author: | Sam Powell [ Sun Nov 28, 2010 2:56 pm ] |
I guess that is a bonus even if you don't get the discount. They say those Suthern girls are mighty pretty. (Don't let the Northern ladies know I said that.) Sam |
| Author: | 64 Convert [ Sun Nov 28, 2010 5:15 pm ] |
Info....the last FelPro overhaul gasket set I bought contained an O-ring for the distributor, but it was way too fat. I don't know who came up with that size, but I had to search through my collection to find one that fit, and it was much thinner. |
| Author: | gato [ Mon Nov 29, 2010 8:21 pm ] |
i have 3 distributor bodies on my bench and they all take different sized O rings. i also found one to set in the tapered space where at the top od the dizzy hole. D~~~! |
| Author: | kesteb [ Tue Nov 30, 2010 9:44 pm ] |
My Felpro gasket set had a bunch of O rings, non of them would fit. So I didn't bother using one. No leaks. |
