| Bling For My Volare (Duster) https://slantsix.org/forum/viewtopic.php?t=42714 |
| Author: | Greg Ondayko [ Sat Nov 27, 2010 2:29 pm ] |
| Post subject: | Bling For My Volare (Duster) |
Well I finally got some new wheels and tires for the '79 duster that I drive everyday. I got Some 17X8 Bullitt Type Mustang rims and some p245/45/17 Tires off craigslist. This combo requires the use of a 1.5" spacer to work. So I got the tires mounted on the rims and got the wheels and adapters on the car. They look real good. I might keep them on a day or 2 more before the Winter Studs and Steelies go on for a few months. Pics: The old Wheel and Tire combo Weighed in at 41# ![]() ![]() The New Wheel And Tire Combination Weighs in at 45# ![]() ![]() Plus 4# for the 1.5" spacers. ![]() Spacers installed ![]() ![]() Stylin. ![]() Thanks to these folks for their cars / Ideas: Brian T. AndyF Look a few replies down on the post. Cant Forget Lou and Josh Skinner too. Greg |
| Author: | Joshie225 [ Sat Nov 27, 2010 3:27 pm ] |
1.5" spacers? You must have gotten the later model wheels with more than 30mm offset. |
| Author: | Greg Ondayko [ Sat Nov 27, 2010 3:48 pm ] |
Quote: 1.5" spacers? You must have gotten the later model wheels with more than 30mm offset.
I am sure its possible..I am not all that knowledgeable about the mustang wheels, but I do know that without the spacers the wheels would be hitting some suspension components on my car. Greg |
| Author: | Joshie225 [ Sat Nov 27, 2010 4:36 pm ] |
The current generation (2005+) Mustangs have higher offset wheels than the previous generation. The 4th Gen 17x8" wheels are all +30mm from what I've seen. They need a 1" spacer on the rear end of an A-body and will fit over the ball joint on the front if the grease fitting isn't too tall. |
| Author: | 70valiant [ Sun Nov 28, 2010 4:39 am ] |
Good luck getting it to pass inspection with those spacers Greg. |
| Author: | Greg Ondayko [ Sun Nov 28, 2010 6:07 am ] |
Quote: Good luck getting it to pass inspection with those spacers Greg.
Yeah, I kinda thought the same thing.I have another set of wheels / tires for that purpose. Greg |
| Author: | ESP47 [ Fri Dec 03, 2010 7:44 pm ] |
I must be tired, at first glance I thought that scale was your speedometer at first lol |
| Author: | Brussell [ Mon Dec 06, 2010 4:58 am ] |
@ESP47 - Same here. Looking good! |
| Author: | 66aCUDA [ Mon Dec 06, 2010 6:56 am ] |
looks nice Greg. Frank |
| Author: | Greg Ondayko [ Mon Dec 13, 2010 1:39 pm ] |
Thanks Frank!!! This is the same car that you saw at the banquet last feb... Now with a bit more style in the non-salt months! Greg |
