| 74 Dart dash lights https://slantsix.org/forum/viewtopic.php?t=42786 |
| Author: | Nongan [ Sun Dec 05, 2010 12:30 am ] |
| Post subject: | 74 Dart dash lights |
Don't have any, any suggestions? Fuses are good, wires are good, panel on the back of the cluster is corroded and pins are missing. Could i run a bulb straight from the battery to a toggle switch to the cluster? |
| Author: | Josh P [ Sun Dec 05, 2010 1:37 am ] |
Suggestions for what? Do you not have dash lights, or are you referring to a slight dimming at idle (very common with stock alternator)? |
| Author: | Greg Ondayko [ Sun Dec 05, 2010 5:00 am ] |
If the PCB is corroded and there are no pins back there I say you need to get a new gauge cluster or at least a new PCB to get thing operating correctly.. If there are no pins that meas no elect. getting to anything in the Gauge cluster.. Greg |
| Author: | Nongan [ Sun Dec 05, 2010 12:16 pm ] |
Well, on that circular connector in the back I'm missing probably 4 of them. But also where the bulbs fit into the circuit board it is all corroded. |
| Author: | Greg Ondayko [ Sun Dec 05, 2010 12:25 pm ] |
New gauge cluster is in order then... maybe Hit up MIDI on this board - I am sure wildcat auto wrecking would have one for you and they are close to you in the Northwest. Greg |
| Author: | Nongan [ Sun Dec 05, 2010 3:16 pm ] |
I figured that might be what is happening, I might have one with my spare parts but i sent a PM to MIDI |
| Author: | zorg [ Mon Dec 06, 2010 7:09 pm ] |
MIDI isn't @ Wildcat anymore. However, their website with a phone number, etc. is wildcatmopars.com You could also post an ad in the 'parts wanted' section of the board here. There are a couple on ebay right now too. Hope that helps. |
| Author: | Nongan [ Mon Dec 06, 2010 8:51 pm ] |
Thanks for the heads up. I have one of their business cards from when I went to the PIR swap meet. Thought about all american classics, I got my driver fender from them for 150 with no rust. |
| Author: | Greg Ondayko [ Tue Dec 07, 2010 2:23 pm ] |
Quote: MIDI isn't @ Wildcat anymore.
Did not know that.. thanks for the update. Greg |
