| 1bbl Carter Carb problem https://slantsix.org/forum/viewtopic.php?t=42796 |
| Author: | VIATVNOW [ Mon Dec 06, 2010 3:31 pm ] |
| Post subject: | 1bbl Carter Carb problem |
What makes a carb go bad? I replaced the carburetor in my truck two years ago and it was running fine until last week. First a lot of carbon came out of the tail pipe. Later it would stall and surge. Now it is very hard to start. Is there an easy fix or should I replace the carburetor again? It seems like it is flooded. |
| Author: | 4speed [ Mon Dec 06, 2010 3:57 pm ] |
check the choke-does it open when hot? |
