cam selection for /6 turbo motor
https://slantsix.org/forum/viewtopic.php?t=42808
Page 1 of 2
Author:  Turbo Toad [ Tue Dec 07, 2010 5:25 pm ]
Post subject:  cam selection for /6 turbo motor
Hay guys and girls I need some help in selecting a good cam for a turbo build
1. the car is a 62 valiant
2. 833 OD trans
3. 8 3/4 rear 2.76 or 3.23 sure grip
4. over sized valves with 340 springs ported and polished head
5. Clifford four barrel intake with a 650 holley dp carb set up for blow thru
6. stock bottom end till I can see some results:)
7. Haven't upgraded the oil system yet but its on the list
8. the turbo I got is a garrett gt3271
9. msd ignition 6al with btm control
10. I plan on building my own header but I may just alter a stock manifold
please let me no all the help is much appreciative
Aaron
Author:  VG-265 [ Tue Dec 07, 2010 11:55 pm ]
I would try it with a stock cam for a start.
Author:  Shaker223 [ Wed Dec 08, 2010 4:33 am ]
went 11.70's @ over 116mph with a stock cam.
Author:  Turbo Toad [ Wed Dec 08, 2010 12:43 pm ]
Hay shaker223 good to see u on /6.org too. So I should beAble to run a stock motor with a good ported head and put out some good numbers?
Aaron
Shaker what track do u run at. I live in Mich to in the Jackson area
Author:  turbo66valiant [ Wed Dec 08, 2010 2:23 pm ]
I got a .465 lift 220* at .050 cam. How fast do you want to go? You gotta pull the head to change cams so you might want to go with a bigger custom right away. Custom Erson cams are reasonable. I may go bigger this year to make sure I reach my goals. Later
Ryan
Author:  Turbo Toad [ Wed Dec 08, 2010 5:06 pm ]
Ryan what's up.
My goal is high tens low elevens.
If I go with a upgraded cam should I also change lifters as well?
Also should I look into arp bolts for the internal components,is there a complete kit of do I have to buy the sets individualy?
Also I read a lot about copper head gasket where do I find one of those?
Lastly who makes a good gasket kit for the /6
Thanks Aaron
Author:  Shaker223 [ Wed Dec 08, 2010 6:34 pm ]
I usually run at Lapper dragway.
Hussy copper will make you a head gasket just about any thickness you want. Seach the site. There was a group buy here last year.
Author:  emsvitil [ Wed Dec 08, 2010 7:27 pm ]
Thanks Aaron
You should always change the lifters with the cam.
After breakin, each lobe and lifter becomes a matched set. So if you ever remove the cam and lifters, remember which lifter goes with which lobe.
Author:  turbo66valiant [ Thu Dec 09, 2010 10:18 am ]
Say, I have the .046 Hussey copper and a felpro set. make sure you get the intake gasket from 66aCuda. Shaker would know if there is another set of head bolt available. I think there was about 7 custom sets made at the higher 220,000 psi? I didn't know there was a group buy on the copper sets. I paid around $80 each. Later
Author:  Shaker223 [ Thu Dec 09, 2010 12:57 pm ]
$80 is what I paid for my gasket....66aCuda has the spare set of head studs. Check to see if he is willing to part!!!
Author:  Turbo Toad [ Thu Dec 09, 2010 5:39 pm ]
So I've done some research and I was wondering if I use a copper gasket do I have to o ring the block or the head?
Also I was looking in hussey catalog and I didn't see the /6 mentioned in the catalog?
Aaron
Author:  Shaker223 [ Thu Dec 09, 2010 6:35 pm ]
You need to call Hussy. You need to know the gasket thickness you want. Turn around was pretty quick. The block, head or both should be o-ring'd. I did the block only.
Author:  Turbo Toad [ Fri Dec 10, 2010 2:27 pm ]
I got a hold of 66acuda and got a intake gasket no luck on the arp head bolts
Aaron
Author:  turbo66valiant [ Fri Dec 10, 2010 3:55 pm ]
O-ring the block
Author:  Shaker223 [ Fri Dec 10, 2010 4:42 pm ]
yup!!
http://www.flickr.com/photos/18510442@N ... 979/"><img src="http://farm4.static.flickr.com/3064/230 ... 5c485e.jpg" width="400" height="300" alt="Oring" /></a>
Page 1 of 2 All times are UTC-07:00
