It is currently Sun Nov 29, 2026 1:14 am
PostPosted: Thu Jul 12, 2012 2:08 pm
My BBS carb looked like it was slightly leaking where the fuel line adaptor fitting goes into the carb.
So I was going to reseal it (better I hope) and adjust the float level.
I took the carb top off and lifted it away.
As I lifted, the accelerator pump came off with the top.
Then it dropped out.
The accelerator pump spring has sprung somewhere and I can't find it.
So I need the dimensions of this spring ( length, number of coils, wire diameter) so I can rewind another spring.
Tanks
 Post subject: And Then....
PostPosted: Thu Jul 12, 2012 4:27 pm
And then I heard a small metallic
DINK
sound as I put the accelerator plunger back in......
Sure enough, I popped out the ball bearing check valve....
Luckily I had 1 ball bearing left in my old carb kit (I keep the old balls just in case...)
Version 2 of the spring (Version 1 seemed a little long, so I snipped off a few coils) seems to be doing the trick.
:D
And the fuel inlet seems to be staying dry too...
