It is currently Fri Nov 13, 2026 3:19 pm
PostPosted: Sun Dec 12, 2010 12:29 pm
What is the best way to clean up the oxidized portions of the printed circuit board(mine is from a 65 Dart) where bulbs, grounds, guage terminals, & harness attach?
Chemically?
PostPosted: Sun Dec 12, 2010 12:40 pm
If it's not too bad you can use a pencil eraser.
PostPosted: Sun Dec 12, 2010 1:46 pm
There is no "white corrosion" just a darkened brown appearance from what I'd call as perfect "as new" brillant copper appearance.
PostPosted: Sun Dec 12, 2010 3:42 pm
Car Model: '23 T-bucket
I second the pencil eraser. It's about the mildest abrasive attached to a stick you can get. I use them at work for relay and contactor contacts. Cleans up the tarnish, and doesn't remove any metal to speak of.
Roger
PostPosted: Sun Dec 12, 2010 6:02 pm
I have had good experience cleaning electrical component surfaces using DeoxIT; I got it at Radio Shack.
