| Cleaning exposed surfaces of print circuit board https://slantsix.org/forum/viewtopic.php?t=42862 |
| Author: | DonPal [ Sun Dec 12, 2010 12:29 pm ] |
| Post subject: | Cleaning exposed surfaces of print circuit board |
What is the best way to clean up the oxidized portions of the printed circuit board(mine is from a 65 Dart) where bulbs, grounds, guage terminals, & harness attach? Chemically? |
| Author: | Joshie225 [ Sun Dec 12, 2010 12:40 pm ] |
If it's not too bad you can use a pencil eraser. |
| Author: | DonPal [ Sun Dec 12, 2010 1:46 pm ] |
There is no "white corrosion" just a darkened brown appearance from what I'd call as perfect "as new" brillant copper appearance. |
| Author: | GTS225 [ Sun Dec 12, 2010 3:42 pm ] |
I second the pencil eraser. It's about the mildest abrasive attached to a stick you can get. I use them at work for relay and contactor contacts. Cleans up the tarnish, and doesn't remove any metal to speak of. Roger |
| Author: | KBB_of_TMC [ Sun Dec 12, 2010 6:02 pm ] |
I have had good experience cleaning electrical component surfaces using DeoxIT; I got it at Radio Shack. |
