It is currently Mon Jun 01, 2026 8:57 am
PostPosted: Sat Dec 18, 2010 5:45 am
are any OE harmonic balancers worth using? or did they all have bonding issues? the one in question is from an 85 truck
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
PostPosted: Sat Dec 18, 2010 11:05 am
At this age and time you have to check to see if the timing mark lines up at true TDC and hope that it stays there. If you want a direct replacement the Aussie Powerbond damper is a nice piece and is priced quite reasonably.
http://www.hdmaddog.com/Dodge-Plymouth- ... 02945.html
