starting without the dash
https://slantsix.org/forum/viewtopic.php?t=42949
Page 1 of 1
Author:  Brussell [ Mon Dec 20, 2010 2:56 pm ]
Post subject:  starting without the dash
Hey,
I pulled out the dash of my 67 vc valiant.
now if I turn the key etc it won't start, what wires do I have to connect to what to get this to work....?
Thanks.
Author:  Doc [ Mon Dec 20, 2010 3:09 pm ]
You need to re-connect the large black & red wires that went to the alturnator gauge.
Author:  Greg Ondayko [ Mon Dec 20, 2010 3:31 pm ]
You need to re-connect the large black & red wires that went to the alternator gauge.
Should he just bolt both wires together to each other, or put the Alt gauge between them?
Author:  4speed [ Mon Dec 20, 2010 3:49 pm ]
Just bolt them together.
You may want to look for the neutral safety switch if automatic.
Author:  wjajr [ Mon Dec 20, 2010 3:51 pm ]
Bolt & nut the two eyes (black & red) together tightly, and tape the splice up using 3M’s 33 electrical tape, “the good stuffâ€￾. You don’t want that wire grounding out & melting everything back to the battery while it is flopping around with no dash to protect it, or its connection coming loose. The amp gage need not be connected.
