It is currently Wed Jun 17, 2026 10:31 am
 Post subject: kickdown lever solution
PostPosted: Sun Oct 13, 2002 10:43 pm
I see alot of post for people looking for kickdown lever solutions. Here is one that claims to work with the slant 6.
http://www.bouchillonperformance.com/BPEtkdc.htm
lasergame@prodigy.net
PostPosted: Mon Oct 14, 2002 12:10 am
: I see alot of post for people looking for
: kickdown lever solutions. Here is one that
: claims to work with the slant 6.
I would not purchase from this company. Last yesr I called them about a engine mount kit, to install a big block into a 89 dodge pick up. I told them it had a v-6, and was told the kit would fit (it did not). When I called about the problem, I was told, "I spoke to the wrong person", when I enquired about application and order, that the kit does not fit the the V-6 truck, do to a different cross member. They would not take the kit back, or refund my money. Also their attitude, left a lot to be desired. I would use the Lokar kickdown cable. It is available from Summit.
flturbo6@aol.com
 Post subject: Bad Service = Bad Press
PostPosted: Tue Oct 15, 2002 2:54 pm
: I would not purchase from this company. Last
: yesr I called them about a engine mount kit,
: to install a big block into a 89 dodge pick
: up. I told them it had a v-6, and was told
: the kit would fit (it did not). When I
: called about the problem, I was told,
: "I spoke to the wrong person",
: when I enquired about application and order,
: that the kit does not fit the the V-6 truck,
: do to a different cross member. They would
: not take the kit back, or refund my money.
: Also their attitude, left a lot to be
: desired. I would use the Lokar kickdown
: cable. It is available from Summit.
: Charrlie_S
This is what happens when you give bad service, you get bad press. I guess nobody that reads this will be getting their kickdown cables here.
