| OEM Service manual procedure needed for carb rebuild https://slantsix.org/forum/viewtopic.php?t=42995 |
| Author: | diy_darryl [ Fri Dec 24, 2010 10:56 am ] |
| Post subject: | OEM Service manual procedure needed for carb rebuild |
Have a 1984 Dodge D150, 225 SL6 that needs a carb rebuild. It's either partially clogged up somewhere or accelerator pump bad etc...... Can anyone be so kind as to post or PM the factory service procedure as I have not yet obtained a manual. I think it is a single bbl Holley 1945 if I remember correctly, whichever carb is stock? |
| Author: | Fopar [ Fri Dec 24, 2010 11:48 am ] |
Look here http://www.slantsix.org/forum/viewtopic.php?t=33102 Richard |
| Author: | diy_darryl [ Fri Dec 24, 2010 12:06 pm ] |
Thanks, I just found that page after I remembered the search function. |
