| Specs https://slantsix.org/forum/viewtopic.php?t=4300 |
| Author: | 225duster [ Tue Oct 15, 2002 7:07 pm ] |
| Post subject: | Specs |
does anyone know the stock 225: block height(center line of crank to deck)? Piston compression height? valve to piston clearance(stock cam and rockers)? Stock Rocker arm ratio? Stock cam specs(lift int. and exh.) and duration for both thanks |
| Author: | Chuck Rivers [ Wed Oct 16, 2002 1:33 am ] |
| Post subject: | Re: Specs |
You might find some answers in Doug's stroking article at <A HREF="http://slantsix.org/articles/stroking/s ... ing.htm</A> Chuck Quote:
: : does anyone know the stock 225: block : height(center line of crank to deck)? : : Piston compression height? : : valve to piston clearance(stock cam and : rockers)? : : Stock Rocker arm ratio? : : Stock cam specs(lift int. and exh.) and : duration for both : : thanks sl6@omnipages.com |
| Author: | Doctor Dodge (Doug Dutra) [ Wed Oct 16, 2002 2:17 am ] |
| Post subject: | Re: 225 / 198 Engine Specs |
: Does anyone know the stock 225: block : height(center line of crank to deck)? See this link: <A HREF="http://slantsix.org/articles/stroking/worksheet.jpg">http://slantsix.org/articles/stroking/worksheet.jpg</A> (10.68" appx) : : Piston compression height? ------(1.765" stock) : : Valve to piston clearance(stock cam and rockers? --------- well over .300 but it's best to check. : : Stock Rocker arm ratio? ----(1.5 advertized but they are more like 1.48 + / - .02) : : Stock cam specs (lift int. and exh.) and duration for both --- (See the link:) DD Stock Cam Specs. |
