| Fabricating super-six kickdown linkage https://slantsix.org/forum/viewtopic.php?t=43002 |
| Author: | trent [ Sat Dec 25, 2010 5:29 am ] |
| Post subject: | Fabricating super-six kickdown linkage |
I'm having a tough time locating a kickdown linkage for my super-six setup. Has anyone here manufactured one or modified the 1-bbl linkage to do the job? What's different? I've got a welding rig, so I figure one can be made if I can get some critical dimensions. |
| Author: | 66aCUDA [ Sat Dec 25, 2010 5:36 am ] |
I have asked that a few times. Always ended up going to a cable style (Lokar) setup. Frank PS is you get a good clean setup post pictures as more than a few folks would like to make one. |
| Author: | terrylittlejohn [ Sat Dec 25, 2010 7:20 am ] |
i haven`t used it yet but i have scraped a couple of mid to late 90`s dakota pickups and the kick down cable with brackets look like a workable setup |
| Author: | wjajr [ Sat Dec 25, 2010 9:28 am ] |
BEP kick-downkitis about the same as a Dakota factory set up. |
| Author: | 1980volare [ Sat Dec 25, 2010 9:40 am ] |
i used a lokar on mine, pretty easy if you are handy. very old picture, but still the same setup 2 years later
| Author: | raPoM [ Sat Dec 25, 2010 2:07 pm ] |
Quote: i haven`t used it yet but i have scraped a couple of mid to late 90`s dakota pickups and the kick down cable with brackets look like a workable setup
Any magnum/auto setup uses this cable. Its the only way to go if you dont want to spend $$$. I had a whole 17.50 in my kickdown that was on my dart. Got the cable and bracket off of a mid 90's 1500 and spent an hour installing it and it worked great.
| Author: | trent [ Thu Jan 13, 2011 11:11 am ] |
Quote: i used a lokar on mine, pretty easy if you are handy.
Do you recall which Lokar model number you got?
very old picture, but still the same setup 2 years later ![]() |
| Author: | 1980volare [ Thu Jan 13, 2011 11:38 am ] |
http://www.summitracing.com/parts/LOK-KD-2904HT/ |
| Author: | olafla [ Thu Jan 13, 2011 10:27 pm ] |
Summit also have extra-long versions of the Lokar cables. Olaf |
