It is currently Sun Oct 25, 2026 12:47 pm
 Post subject: Specs
PostPosted: Tue Oct 15, 2002 7:07 pm
does anyone know the stock 225: block height(center line of crank to deck)?
Piston compression height?
valve to piston clearance(stock cam and rockers)?
Stock Rocker arm ratio?
Stock cam specs(lift int. and exh.) and duration for both
thanks
 Post subject: Re: Specs
PostPosted: Wed Oct 16, 2002 1:33 am
You might find some answers in Doug's stroking article at <A HREF="http://slantsix.org/articles/stroking/s ... ing.htm</A>
Chuck
: does anyone know the stock 225: block
: height(center line of crank to deck)?
: Piston compression height?
: valve to piston clearance(stock cam and
: rockers)?
: Stock Rocker arm ratio?
: Stock cam specs(lift int. and exh.) and
: duration for both
: thanks
sl6@omnipages.com
PostPosted: Wed Oct 16, 2002 2:17 am
: Does anyone know the stock 225: block
See this link: <A HREF="http://slantsix.org/articles/stroking/worksheet.jpg">http://slantsix.org/articles/stroking/worksheet.jpg</A> (10.68" appx)
: Piston compression height? ------(1.765" stock)
: Valve to piston clearance(stock cam and rockers? --------- well over .300 but it's best to check.
: Stock Rocker arm ratio? ----(1.5 advertized but they are more like 1.48 + / - .02)
: Stock cam specs (lift int. and exh.) and duration for both --- (See the link:)
Stock Cam Specs.
